sharkey
Just this guy, y'know.
Welding Cart for SIP weldmate:
Made out of bits of square and angle stock and a trolley I got for $17 and cut to pieces. The regulator is at just the right height to read the gauge over the top of the welder, and the axle runs through one of three tubes under the gas tank so I can get the balance point just right. Still needs a couple of bits of tube tacked to it to holster the gun between welds.
RSJ Trolley:
Rolls along the RSJ which runs across my workshop, the rubber wheels are only rated to 100kg each but that's plenty for lifting motorcycle engines in and out of their frames and up onto the workbench. The axle tubes are 3/4" with 3mm wall thickness, they're just butt welded into the vertical tubes, I probably should weld on a strap over the axles just in case.
RSJ Trolley:
on both ,the wheels on that welder stand are beefy ,i love it !
. So don't give me Tiny, when it comes to projects they don't come much smaller than mine
