Can anyone tell me why my cebora 200 has 2 gas inlets for the shielding gas and also has two triggers for the gas(one normal one on the front of the torch and one little one on the back of the torch)?
For those who may be interested. I have found that the torch is a weld-ex 95 which has a fire extinguisher function on the back of the torch which allows a jet of Argon/CO2 at 10 times the normal rate to put out a flame. According to what I have read its a retro fit torch. Only problem now is finding contact tips that will fit as they have a larger thread than a normal euro torch!
Interesting idea! How does it work though? The gas flow is controlled by the regulator so should be the same pressure at the torch unless it uses some sort of adapter at the reg.
So far I havent had to try it. But the second gas feed comes from a Y connector at the regulator so I agree that It probably wont supply any more gas than normal. It should probably be connected to a seperate bottle.
Does anyone know where to get parts for this thing?
