Because it's a solution to a problem that doesn't exist.Richard why dont you invest £5.95 for 2 diamond wheels and give them a try? Its not much money, and I think like me you would never want to use a grindstone again.
And the dust that is of more concern is the actual tungsten. Your gonna get that in any grinding process with any wheel unless you used an enclosed device.My ONLY comment for the Diamond wheel is less dust,
BUT if dust is not an issue, A bench grinder is ALL YOU NEED.
far better to consentarte on improving other parts of the welding process
I'm failing to see any real benefits. I can already get the prep done in a matter of seconds. I'm more up for utilising my time in more productive areas than making adaptors for something that isn't going to change its performance. If I showed you my tungstens you'd see they don't need a different wheel to improve there performance.
One benefit of using the wheel I linked to is that you can produce beautiful mirror-finish cutting edges on lathe tools and drill bits. Grind your tool normally then finish the edge with a lick on the diamond wheel. Then keep your fingers away from them because they are damn sharp.
Off track a bit but I use a diamond to hone my lathe cutting tools after grinding. They cut so much better & leave a nicer surface. I keep it on my lathe to touch up between grinds. I actuality don't regrind one unless I need to turn it into a different tool cause the diamond only takes a few strokes. I shape some carbide also & that is my reason for converting.
I have a diamond wheel I got from eBay that I made a arbor to run it in my lathe or mill but it only gets used for specific jobs. I also made an arbor to use a 3" saw from my biscuit jointer. It works a treat in my mill.
