AnthonyExmouth
- Devon
My 8" grinder wheel needs replacing, what's the best wheel or disc I can replace it with for grinding my tungsten?
I don't understandDo you mean W or WC? Likely a different answer for each.
I reakon a diamond wheel
No, that's a welding mask, no good for sharpening tungstens.
Just been using the fine grit wheel that came with the grinder, decided to get a second grinder so I could keep it dedicated for the Tig, came with a course wheel too but wondered if there was a better option. The wheel kicks out so much dustI just use a standard wheel, dedicated for tungstens.
I changed the linkNo, that's a welding mask, no good for sharpening tungstens.
Glad I was sat down when I saw the price
mine was about £20 thats the first link that popped upGlad I was sat down when I saw the price
Do you grind on the edge or face of the wheelmine was about £20 thats the first link that popped up
Always on the end of the wheel, not the sides.Do you grind on the edge or face of the wheel
depends on grinder and disc or wheel type!Always on the end of the wheel, not the sides.
Bench, just a cheap titan 8" one from Screwfix to keep as a dedicated tungsten grinder to stop contaminationare u using a bench griner or a angle griner?
Even with that skinny diamond wheel?Always on the end of the wheel, not the sides.
if it was mine on the end of the wheel then with a diamond coated discBench, just a cheap titan 8" one from Screwfix to keep as a dedicated tungsten grinder to stop contamination
