angellonewolf
- bristol england
as above daughter has a beko dryer that just hums when starting if you remove the lid and give the drum a shove it works fine
ive found the capactor its a 8uf -+5percent the ones on line are 9uf same spec volts etc even the ones listed for my mechine are 9uf
can i get away with a 9uf cap ive allway been told same spec uf but can use a higher voltage
any ideas ?
any ideas ?
