Does anyone in the UK sell dies/mandrels to use in a hydraulic press?
Im trying to flatten (form?) the end of steel tubing so that I can then make it into brackets. Im not sure what the technique is called either...?
I use the Vice to flatten the ends of tube then you round off with the grinder drill hole and hey presto , little tip , if the tube has a seam make sure its not on the tip of the flat as tube will split !
