hi have just found welding forum and just like to thank everyone who has placed stuff on about sip welders and wire feed stuff have been trying for years to get to grip with my sip 150 welder and every thing i have been reading ive expirienced so a big thank you
have a issue with my gas delivery valve a mestiner italy i was welding the other week welding good clean box section and had got my sip set up good with a 6mm bolt large spring and repair washes holding wire reel in place on mounting got wire feed sorted
when the valve started leaking from what i suspect is a pressure releaf it was a constant leak so unscrewed said bolt with a hole in it there was a spring and seal in it refitted it but still leaking is it possible to replace seal if yes were do i get this from cheers
