RonA
specialist in repairing sealed for life equipment
- Stockton on Tees, UK
Hi I own a Myford ML7 lathe but have always had trouble with parting off tools on steel stock.
I've tried carbide tip tools & recently purchased a quick change toolpost which came with one holder which takes a special HSS parting tool.
I always seem to get chatter on the tool despite changing workpiece speed & tool feed rates. Anybody have an tips or ideas to get a more even cut without the tool chatter. The tool tip is. aligned with the workpiece centre point
Any thoughts great fully accepted.
RonA
RonA
Machine rigidity has more effect on the outcome than owt else, I'd say. Make sure cross and top slide are wound in as much as feasible, and lock the saddle and top slide if possible. You want to remove as much slop from the equation as you can. Get the blade cutting in without being too forceful else fearful, then just cross your fingers and hope.
grind tungstens on it
