well i have had success on something like that, with a standard large pipe cutter just rolled around it cannot come out of the thread and it just rolls it back into shape.
I think I'd run that I the 4 jaw and tidy it up that waty
yes obviously not tight enough to start cutting the shaft! just have to play with it where it is tight dont force it do it gradually, if you have spare discs you can take the sharpness off it on some old shafting you are not bothered about or touch it with very fine flap wheel so that it turns with the disc to keep it even.Do you set the pipe cutter so that it's a loose fit, with the roller(s) just touching the other side of the shaft/spindle, but not tightened up fully?
I would stick it in an envelope and send it to @Double Boost he has finished that great big steam truck now. Lol.Do you set the pipe cutter so that it's a loose fit, with the roller(s) just touching the other side of the shaft/spindle, but not tightened up fully?
I may end up going that way if I don't sort it via other means. One of those occasions where it would help if I actually had any of the lathes setup and running.![]()
Interesting. A bit of research showed claas olsend used to sell it. But don't anymore. It's available on ebay from Huddersfield but a website claims to be sole supplier in the uk and price is almost the same at 105 quid...http://toolguyd.com/threadmate-tools-repair-just-about-any-threads/
this is the same as snapon tool,and where i got the idea of using pipe cutter because they are a similar idea
You may find something here
https://www.grainger.com/category/ecatalog/N-1z0drsx
Yeah but nice for us to watch..How embarrassing would that be though, sending it to someone else to machine, when I have N amount of lathes here.![]()
I know I keep pestering him for a quick tour of his storage options as I am trying to tidy my garage and workshop.Knowing DB, he probably already has a list as long as his arm of things to do future videos on.![]()
