A collegue who is an extermely well experienced welder has a failed TT180. The fault is poor/no performance of hi frequency. The same fault occured some years ago & he was advised to change the 0,002Mf 10 000 mwv capacitor whiched fixed the problem. I can only check this capacitor with a 1000v tester but at that voltage the capacitor holds a charge. can you advise where we may obtain this capacitor please( I have physical dimensions but space not important) & the likely cost. can you suggest any other areas to be tested? The only other noticeable aspect when trying to use the welder with hi-frequency on is a very erratic discharge across the spark gap.
We are aware that these welders came from Australia & spares are difficult to come by.
Thanks for any light you can shed.
