Oh yeah - worn injectors (lumpy Idle, stalling - then beware - you could be looking at a 1k bill).
ECU & immobiliser issues as well.
All that said - there are lots of the things still running.
(I just replaced the front wheel bearing on a mates RWD 57-plate Transit - that's a ballache too, as the disc is behind the hub, & the bearing carrier is behind that, and it's all pressed-together F-in tight, with the torx bolts for the bearing carrier needing to be accessed through small holes in the hub/wheel carrier & the disc. Rubbish arrangement.).
