oops rwdFront or rear wheel drive?.
thanks.Thanks, it's more common for the linkages on fwd boxes to seize up.
Is the lever stiff going side to side, or Only back and forth or both? I would first be popping the cable ends off the selector arm on the gear box. they are on the drivers side of the box and a simple ball and socket fit, they may or may not have a little release button in the centre but if not they come off easy with a pry bar, after they are off check the lever feel, that should Give you an idea on what end the fault lays
Not on a 60 plate with a short lever on the dash, it has cables, something like an 05 with a long lever coming from the floor fits into the top of the gearboxRwd straight into box IIRC?
ok,i didn't presume cables were seized,just that they may be dry.Short for if I remember correctly. I would say your fault lays with the external gear linkage on the box, I have done these before but never done cables for seizing.
