Hi,i recently aquired a old trailor frame witch was a bit worse for ware. so i fixed up the frame with 1/4" angle iron. Made the back gate from scratch witch was my 1st proper peice of actually making and welding from measurements (i was proud of that) but now im at the point of flooring and sides i was thinking of using sheet metal but im not to sure on the thickness as i only have a ARC welder
So my question is what else could i use to hold it in place?
Or what would you guys use?
or use pop rivets?
I use outdoor grade 1/2" ply for my trailer floor held in with a few roofing bolts but if you put it in before the sides it will hold itself in place. I used T&G for the sides just because it looks nice.
