Maddog
- Manchester
Hi guys,
A while ago I bought a nasty old wooden trailer that was totally rotten, but turned out to have a heavy steel motorcycle trailer chassis underneath.
I binned all the wood, welded a new body frame in and skinned it in ally, replaced wheels, mudguards, etc..
The main axle or whatever it's called that the indespension unit are bolted to is some odd sized box section steel ( seems to have an ID of 115mm x 50mm) the ends of which have just been cut off with a grinder and are open to the elements. I was wondering I anyone had any ideas how to seal them?
I have been trying to find some plastic plugs I could hammer in but due to the odd size this is proving difficult.
My other option is to weld some steel over the ends (which I could do, but would be a bit of an ****). The box is about 3mm wall thickness so really I could do with something easy to work with if I'm welding it, but if it is to get a good weld to the 3mm it would need to be around 2mm plate.
Was just wondering if anyone had any easier solutions?
Thanks.
Thanks.
