8ob
- Nescient in the vale
[QUOTE="
As for weight capability, the Amercians put a 3 point linkage on the front of these things which they state will handle 800 pounds. This little cutter only weighs in at 440 ish. 200kg in real money.[/QUOTE]
The weight is of less concern, its more of a leverage problem. Side arms can spin a tractor about if they get snagged, you will need to go steady with it and keep your eyes peeled. On the return line it may pay to butcher a spare cap just for this application, the only thing wrong with running the case drain back to the tank like this is the lack of filtration.
Bob
Bob
, all I do know is from just using my standard 18" electric trimmer, there is a fair loading to pull it through the hedge but even more from using my long arm cutter with a 12" bar, how much force is required at my arms !! coz they ache after ten minutes.
than a hedge that is only cut once a year------ if that,----as are some old gnarled hawthorn field barriers.
Ah fantasy's------- we all have them,--------- most end up being impossibilities
