MetalMonkey
- UK
I've had it with garages doing wheel alignment too. Can anyone recommend any kit which does the job for cheap?
You won't get anything cheaper than a roll of string and a ruler.....
With that you can do a full four wheel alignment.
They sell fancy jigs for stringing if you feel you want to burn money, but none of it is needed if you take your time.
In terms of cost, stepping up from that you have the old Dunlop style gauges, modern clones now using frickin' laser beams. They will just do your front alignment and you need a flat surface.
There was also the old Wheelforce deflection type gauges - I have a battered old set kicking around somewhere, but they don't work with the bumpers on most modern cars.
Then you get the hang on style laser quick alignments with the flags, clones by Tecalemit, QuickTrak, Super tracker etc - available in two or four wheel styles.
Then you are up into the computerised stuff and deep pockets.
