We'll just have to wait and see which part of the plan goes tits up first.Thanks that sounds interesting.
The crank bench? Basically it's a bigger and much more adjustable/flexible version of the commercially available truing stands most of which are only really suitable for small single cylinder two strokes.
The tail stock will be picked up by 50 mm. Then I'll either gut the headstock and raise that by 50mm, or remove the headstock all together and replace it with an upstand. Those two will carry the centres.
The cross slide carriage will be adapted to take interchangeable 'V' blocks with a variety of widths, roller and knife edge bearings etc so that a crank can be sat on those.
With the bed being a nice flat slide surface I can then work on a small two stroke crank that's not much over 100mm end to end and weighs less than a kilo. Slide the tail stock out and I can work on a 4 cyl 4 stroke crank from a GSX1100 that's nearly 600mm long and weighs over 20 Kg. Along with long stroke 2 cyl etc etc. Because it's a solid lump there won't be any issues with bounce or flex.
The extra depth and stability mean that I can mount a depth gauge, DTI, or scribe, I can use a rudimentary index for re-phasing, and if needed I can weld on it.
Given its size and length and the measurements I can take by using it I'll also be able to use it to check gearbox shafts for tru, cam lobe lift and probably a host of other stuff I haven't thought of yet.![]()
Also as a BBQ rotisserie stand for cockroaches and sparrows etc. ?Hog roast at the next gathering?Also as a BBQ rotisserie stand for cockroaches and sparrows etc. ?
Those burgers were good!Hog roast at the next gathering?
With the discount he gives me they're the same price as a big mac meal, but they're better by an order of magnitude.Those burgers were good!
