Thats great, dont know where I got 2000Hz from then2000hz is unheard of as far as ac freq is concerned. You'll not need any more than 120-150 max. Arc stability is by far more important.
Fwiw my fronius goes up to 100hz it's an old machine but I never feel restricted by it as the arc is so sharp and stable.
Don't worry your self about the scope on the bells and whistles. Look for arc stability, HF accuracy and the accuracy of the digital readout ie if you set 100amps you should get 100amps. The rest of it will be fine.
I'm having trouble finding the used equipment section,
Thanks
I must beYou won't get 0.5 hz either. I think your referring to pulse not ac freq. pulse welding is totally different and usually only performed in dc. My Fronius has a massive scope of 0.1-2000. Don't confuse the two as they are very different. Pulse is 2 current settings ac freq is 2 different polaritys.
Thanks PaulClick the forum button at the top of the page, all the different sections can then be found in the list there
Anywhere from 1.2 ally up to 8-10mmBrilliant, That's what I was hoping. What sort of thicknesses are you welding?
Ok this ismy opinion and others may disagree. Pulse on ac is the same as on dc. It bounces between 2 current settings ac freq is different and there is no link between the two things going on. Pulse on ac is pointless. I can do it with mine but never found a use or reason to do so. Pulse on dc for me serves one purpose. Heat input reduction. I use it at high hz (100 min) on thin gage long continuous runs usually stainless where I need to control distortion. I see people using slow pulse to enhance the freeze frames on Tig purely For the stack of dimes effect. I can do that without a pulse so I use high hz to tighten and concentrate the arc.
Pulse and pedal don't offer the same advantages. One offers variable current control On the fly the other offers reduced heat input over a high and low current setting. Not the same thing at all.I use pulse instead of a pedal....
Yes mr shiney but what Richard is saying is that it's not a replacement for the pedal at all, pulse and a pedal both are very different things and have specific uses
Pulse does control heat input mr shiny so there is no arguement there. It's not essential to use on Alu for two reasons.I know exactly what Richard is saying. He is a talented perfectionist. The rest of us are bodgers and get the job done. I very successfully use pulse mode to control heat on jobs as I don't have a pedal or space to use it. There are many ways to skin a cat as they say!!
Also mate I need to make a point. I've seen some of the pictures of jobs you've done and they are hard jobs performed to a good standard. I was particularly impressed with the head fin you did. So saying you've not got talent at welding is daft. I've never welded a head fin back on I've always built them up from scratch and shaped them back so that for me was talent. Just because we don't agree on technique etc doesn't make me any better than you at the torch end.Not everyone is a purist like you. For those of us without talent or the capacity for a pedal it works rather well!!
Black soot and dulling of the tungsten is down to oxides been transferred across the arc.I've got a Kemppi 2300, and couldn't be happier with it. You do need the ACX front panel, and I found a foot pedal necessary for Aluminium.
The only negative is some days I get really crappy looking welds. Sooty, no penetration, munted tungsten.... If I cut it out and do it again it is always ok. So far I'm blaming the machine.![]()
