Thats not to say that the Inferior product won't do everything that a DIYer wants and more.
Yes you could buy a Chinese Plasma Cutter, slice through metal and get a perm at the same time... free! I'll bet Vidal Sassoon is getting worried!
weldequip
Would you dig foundations for a house with a spoon???
Ithought this thread was about a welder not the work ethics and quality of our far east friends.
Basically but an EWM set get a good weld no hassel and low consumable costs.
Buy a cheap set and get frustrated high consumable costs A short set life and give up with it thinking you can not do the types of weld that others can do.
I welded 2 coke tins together within 5 hrs of having my set tring to see how thin it would go. (it would go lower but I could not find any thing thinner to weld) where as the last time I had used a tig before that I was struggling to weld 1.5mm aluminium with help from the 2 best welders I have ever met. I was putting holes all over.
I dont blame my tools as I buy the tools for the job.
Pete
I expect very few members know what an inverter tig looks like on the inside
Once my ewm inverter was out warrenty i decided to open it up and look inside, i soon closed it up and realised there were no user servicable parts in there and any fix was a job for the professionally trained
I thank you for your welcome.
I just need a bottle of argon, flowmeters, tungsten, consumables, a project and a mask.
It would be interesting if we had an inside pic of a modern tig machine.
Also the fan was in a tunnel running through the centre of the set and all the components that need cooling are in this tunnel and the circuit boards are in a almost sealed outer case that is steel this is not seen on any other single phase inverters.
