Oh right! That makes sense.. My assumption wrong then.. Must help with heat dispersion too though surely.. XI may be wrong, but I thought the many holes were for clamping purposes...
Your not wrong. That's exactly what they are for. So you can fit your fab down in any position.I may be wrong, but I thought the many holes were for clamping purposes...
No. Your not going to be heating up the bench noods with a 160amp dc Tig. A 400amp acdc doing hefty Alu work maybe!! If you want something to take heat away from your job a thick flat lump of metal to sit it on and act as a heat sink will suffice. I have a 25mm thick lump of cast that I do my small Alu jobs on. It sucks out the heat quick if the parts are small and becoming heat soaked too quick.Oh right! That makes sense.. My assumption wrong then.. Must help with heat dispersion too though surely.. X
Ok thanks mate, is a solid slab a scrap yard job?No. Your not going to be heating up the bench noods with a 160amp dc Tig. A 400amp acdc doing hefty Alu work maybe!! If you want something to take heat away from your job a thick flat lump of metal to sit it on and act as a heat sink will suffice. I have a 25mm thick lump of cast that I do my small Alu jobs on. It sucks out the heat quick if the parts are small and becoming heat soaked too quick.
That's a proper one.I bought a T slot machine bed for welding use.
Only slight issue being that it weighs well over a quarter of a ton. It's bigger than it looks...
Hoping to make it height and tilt adjustable but it might just end up going in on four legs!
S.
That table is amazingly good ^^^^^^
That's great... Many Qiudlys to buy?I bought a T slot machine bed for welding use.
S.
Ide hate to weld over that to be honest and ide use it as a surface plate and jigging table![]()
