BB are you expecting the Armageddon?
because "Women are irrational and without a man in the house to keep an eye on things she couldn't be trusted"
Unfortunately yesHe actually said/wrote that?![]()
Unfortunately yes![]()
bit late, but they are aerated concrete blocks aka celcon aka thermalite (insulating and lighter due to the entrained air)
you can cut them with a woodsaw and screw straight into them
You do get plugs designed for them, look like a plastic twist bit,
I have thermalites in my place, drill the holes smaller than needed and use more fixings...the substrate isn't as strong as regular dense blocks so fixings can rip out if took much load is placed on too few fixings...
it only needs to withstand a few tugs, its sat on top of my gun cabinet for support so weight isnt going to pull down on the fixings. there are 4 bolts in there and all 4 are tight, i drilled 11mm holes for the plugs which had 12mm written on them and hammered them in, took a bit of force to get the bolts in when they got down to a third left but they are in now.
Could have bolted it to the gun cabinet too?
