Whilst I understand both sides of the program vs gearbox discussion above, and don't wish to take either side, other than to say that a machine with a gearbox will only have two options to change ratios to correctly align metric and imperial. I will add that my own Triumph will cut both, with the proviso that the half nuts are not dis engaged - been there and found it to be true, unsurprisingly. The problem is you cannot turn a big lathe, fully engaged backwards, and if your single phase motor does not have a reversing switch it cannot run backwards...Once you have the right gear selection, you will need to leave the half nuts engaged as the thread dial indication will not be right on a metric machine for imperial or vice versa
So what's the fix? Well I recently had to cut a metric thread, and my answer was to turn a smaller diameter on the end of the shaft, cut a thread into that and use it to restart each new cut - obviously setting the correct depth for every advancement. It worked really well I have to say.
