so will latching it manual if the motors goneIt will get his heating on till BG show up Though
Thanks.Sounds like a pump or circulation problem
Bugger. This is exactly what its doing. The pump is on 3 already. Always has been and its never done this before. Do the pumps gradually fail or just work/not work?yep if the boiler thermostats going on and off all the time the water isnt circulating fast enough to clear the hot water in the boiler and its cutting out .check the speed of the pump if it has 3 settings on it and turn it up if it isnt on maximum .if its 2 fast you will hear it spinning the water round and can be turned down feel the pipe under the 3 port valve and see how hot it is. if the water and heating are both calling for heat the 2 output pipes should all be the same heat as the input from boiler if everythings flowing properly
The levers and change over seem to be working as they should I think. I havent bled the rads for a fair while (cant find the key to do it tonight) - would that make any difference? I havent checked them all but they do get hot.have you tried it on water only and see if it does it , leave heating off and heat the water. once its hot and cuts off on the tank thermostat turn up the thermostat on the heating then see how it goes check all the rads are getting hot and bleed the radiators if needed. when its on heating check the slider lever it should be free to move both ways loose if the motor is holding the valve i fully open
should be ok if there fully getting hotThe levers and change over seem to be working as they should I think. I havent bled the rads for a fair while (cant find the key to do it tonight) - would that make any difference? I havent checked them all but they do get hot.
Just had the water on this morning. Its definitely doing it on that as well.
Is this likely to be a blocked heat exchanger? looks like they are still available for this boiler.
Thanks. I have a homecare visit booked now (but not till 28th April!) I will try not to use it much until then!Unlikely, more a weak pump, blocked tee or if you have any sort of air separator it will be that
What would an air seperator look like? Not an expansion vessel?Unlikely, more a weak pump, blocked tee or if you have any sort of air separator it will be that
Hmmm. Would there be one as standard? I cant picture anything like that from memory and i am away for a few weeks now (was only up there for work)Usually has 3 or 4 pipes, comes off the flow/vent before the pump then up to the tank.
Ive never seen one more than 2 years old not blocked solid
