Hi folks, new to here and looking for some collective knowledge on a problem…
I have a Fabricator 250 which I can’t get wire speed to go past around halfway. Tried all the obvious things I think! and have swapped wire feed motor with another unit and also wire speed control switch. Wire speeds up as you turn dial but around halfway maxes out at a lot slower than it should be. Voltage going to wire feed motor goes up to around 13.5 volts then stops, I assume as it’s a 24v motor it should go nearer to 24v when at full speed? Any thoughts welcome!
Thanks
Thanks
