Hi Gordon, don't worry about it I will try my thing, just need to get a few bearings.
I can get the angle grinder out with a slitting disk and cut it, that’s actually cleaner than a plasma cut, less edge clean up as well, it is just I have to do it at the back of the kit car just outside the garage.
All I am trying to do is find a solution that minimises the noise to the neighbours, because cutting sheet makes a row. I do not have issues with any neighbour that I am aware of, they all speak with me, but I am conscious of the noise I can make. Many of them are retired, semi retired etc and are spending time in their gardens as the nicer weather is arriving. If I can make the simple cutter to fit the overarm of the mill and it allows me to cut slices around 450 to 500mm I will be happy, I can do it with no noise have a clean cut etc.
I have managed to fit my petrol compressor inside my inner insulated room with an exhaust running to the outside. The air line is clipped to the wall and runs to the CNC cutter around 8 metres in length of 10mm pipe. So my plasma is now fixed on a wall closest to my house. Move a few metres from the garage when running the compressor and the noise is nothing but a murmur. Shut the garage doors and run the plasma again within a few feet of the garage the noise is noticeable but not loud, stood next to it when cutting and you need ear defenders. You read that many tales on here about having issues with next door, it is just not a situation I would like to get in. I did have a bad neighbour at a previous house, these are like pure gold.
The initial question was basically asking anyone if they thought the idea with a bearing as a test out would work, I will try out out anyway, if it does yea! It it does not, then, Oh well.
I will post pictures and results as I go along, but I need the bearings first.
Cheers
Adrian
Cheers
Adrian
