hermetic
When voltage drops, current rises ! The reason we transmit power at high voltages like 11kV and up is because the current falls. take a 240 volt supply and put a 1kW load on it. 1000W/240v= 4.16 Amps. Run the same load on 100V and you get 1000w/100V= 10Amps Resistance is measured in ohms, but power dissipated is in WATTS The resistance of any heating element will not give a true current reading when applied to a circuit using alternating current. Hence a 3kW fan heater on 240V draws a current of 3000/240=12.5 amps Pedants be aware that this is a simplified version of the truth!!!
Phil
Phil
they cant see that the plug and the socket both need changing at the same time otherwise one burns the other out by overheating
