Moose McAlpine
- Norf Lund'n
Thats where an EV "shines" - low weight - low battery capacity - low range - low mileage - low amp charge at home at the right money per Kwh.
EVs peaked with the milk float.
I know! I've been keeping my eye out for one for agesThe 6 cylinder diesels of that era are a far more reliable engine, looked after they go on forever and a day, and there’s not a huge difference in fuel economy.
Any 6 cyl sounds like sex on legs compared to the clatter of the 4 cylinder versions, spend all that money on a car and have it sound like a tractor!The 6 cylinder diesels of that era are a far more reliable engine, looked after they go on forever and a day, and there’s not a huge difference in fuel economy.
Demonstrably they can be more than town cars.... but arguably the tech is far less stressed and more suited - to lower power, lighter duty, commuting type roles. Batteries & the physics involved has always seen batteries do better at low loadings, than at high loadings, and slow charging is kinder as well to the battery - so again "home - to - home" circular route, reasonably local commute..... I don't see it as unreasonable to think that this is the best role for the tech - esp when this is also when it's ability to have its pollution generated elsewhere & not in the urban environment - comes into its own.We’ve had a 200 mile range ev as a family barge for 4 years and it’s been brilliant. To suggest they can “only be town cars” is crazy, given it’s easily the most comfortable/quietest motorway cruiser I’ve ever been in. It does the wife’s usual commute (~8 miles each way every day), plus when she works away which is 60-70 mile commute, ferrying the daughter to swimming, tip runs, taken the 4 of us + dog + luggage 120 miles each way on holiday regularly and everything else we’ve asked of it. 40,000 miles, 1 service, two puddle lights replaced under warranty and still only halfway through the second set of tyres. (First set lasted just under 20,000 miles but lots of owners seemed to complain of the oem tyres having less tread depth than usual)
Had range anxiety the first day we had it and never since.
Don’t think I’d disagree with much of that, I’m just pointing out that our situation (which I’d say is fairly typical requirement for a family car) hasn't required massive range or performance, and the car has done the job you’d ask of any car, electric or petrol. It’s excelled at comfort, quietness and space. Its easy to drive (my wife doesn’t give a hoot about performance or handling, just wants a car that goes and stops with the least amount of fuss), copes superbly in traffic/town and does just fine on longer journeys.Demonstrably they can be more than town cars.... but arguably the tech is far less stressed and more suited - to lower power, lighter duty, commuting type roles. Batteries & the physics involved has always seen batteries do better at low loadings, than at high loadings, and slow charging is kinder as well to the battery - so again "home - to - home" circular route, reasonably local commute..... I don't see it as unreasonable to think that this is the best role for the tech - esp when this is also when it's ability to have its pollution generated elsewhere & not in the urban environment - comes into its own.
Lighter duties? 320bhp and 446 lb-ft with an 800v system that can charge the battery to 60% in 18 mins. It's the fastest I've ever been up Sutton Bank!Demonstrably they can be more than town cars.... but arguably the tech is far less stressed and more suited - to lower power, lighter duty, commuting type roles. Batteries & the physics involved has always seen batteries do better at low loadings, than at high loadings, and slow charging is kinder as well to the battery - so again "home - to - home" circular route, reasonably local commute..... I don't see it as unreasonable to think that this is the best role for the tech - esp when this is also when it's ability to have its pollution generated elsewhere & not in the urban environment - comes into its own.
No aftermarket parts for this motor. Volvo won't sell Guides, only a bare head. For 2 Grand. Nett. Trade!
Lightweight...Any 6 cyl sounds like sex on legs compared to the clatter of the 4 cylinder versions, spend all that money on a car and have it sound like a tractor!
Older Cast Iron Tractor heads get reamed & lined yes (some have options of 0.003" or 0.015" oversize stem valves instead to compensate for wear)....so in theory yes - but in practice it doesn't seem to be the case for Alloy Head Castings.Can't you just line the guides, used to do quite a lot of this back in the day, ream out for the liner then push a ball bearing down the guide with an air hammer, worked a treat. As far as the rest of the bits are concerned, aren't there any aftermarket manufacturers for springs and such? Can always get the cam reground.
And then when comparing cars at the Dodge dealership in Houston, the V6 sounds like a Ford Focus, but the V8Any 6 cyl sounds like sex on legs compared to the clatter of the 4 cylinder versions, spend all that money on a car and have it sound like a tractor!
