clueless77
One for the sparkies, I have a couple of bench drills with 3 phase motors, both have only 3 connections at the motor. just tested one of them through the pins of the 4 way plug. I meggered at 1000v from earth to each pin and got 4.2 meg on each one. continuity between earth pin and chassis of drill is 0.1 ohm. Testing from pin 1-2 I got 100.5 ohms. pin 1-3 I got 98.0 ohms and pin 2-3 got 94.5 ohms. I know nowt about 3 phase motors so do these readings mean it should run? ( not tested the other drill yet). Any advice welcome.
p.s I don't have a 3 phase supply to plug into so can't test that way, just want to test with meter before buying an inverter or whatever the right name is to run both drills off. Cheers.
And thank you for the replies by the way, social skills not my strong point.
