Mrs McDonald
New Member
- Leeds
I hope you don't mind me posting on here. I am a DT teacher in an academy in Leeds.
I have a pupil who is fixing 6mm mild steel rod into a rectangle bar of mild steel, 30cm x 20mm x 9mm
I have a tap and die set and have successfully turned an external thread using the M6 tap on to the 6mm rod.
Not sure what size hole to drill in the bar ? and also which die piece matches the turned 6mm rod..
Hope someone can help.
Many thanks xx
Many thanks xx
