C
Chris Stevens
Guest
The reel I have has been damaged in transit, and is already starting to unravel. If I fitted it to my machine I am 100% certain the wire would get pulled down the side, and jam the wire feed mech.
Its handling........buy the odd one and they dont stand much abuse, buy a pallet and they are fine. Its a bit of an issue but the other side is the recycling. Its a compromise and the more the plastic is outlawed the more of an issue it will become.Been buying MIG wire online for about 5 years now, all plastic reels and not one damaged. First steel cage wire, and its damaged and useless...............
Thats true but I assume their suppliers are. It needs highlighting to them that handling is important. Its a strong pack but throwing it about is likely to damage it.Trouble is not many members of this forum are buying Mig wire by the pallet, so the OPs warning about wire spools seems very helpful to me. Certainly wouldnt have found the ESAB wire I have on a metal spool wasnt usable without opening it first.
I've had a few issues with wire baskets, but no more than I get with plastic. The issue seems to be that if the edge of the wire basket gets dented slightly it spreads away at the side creating a gap for wire to drop into and jam. Plastic that doesn't get hit hard enough to actually break goes back to exactly the same shape as it was before, even if it breaks a portion off the edge its often still useable, but virtually any damage to the side of a wire basket causes a feed problem at some point. In the main most of our spools going out the door are on plastic drums though and we handle it very carefully se we don't want returns on a low margin item.
Bad luck I guess, both work perfectly if handled carefully, its just the metal spools seem a bit more prone to this type of issue. We used to get fun and games with spools shorting out on casings of welders in the past too but most manufacturers seem to allow for this in the design of their sets these days with a bit more clearance around the spool.
Exactly the problem, and not something I have ever experienced with plastic spools over more than 20 years of Mig welding. First and only wire spool I have tried is not usable..................
Replacement reel of ESAB wire arrived today.Wire cage badly distorted, and one of the welds broken. I think its a very good idea to avoid Mig wire on steel spools if at all possible........................
yes
