shenion
Tool Pack Rat
- Stone Mountain, GA USA
Ok, here is my vintage beast: http://shdesigns.org/Welding/airco.html
This is one of the 3 welders I got in my Ebay steal as mentioned in the "I wish I had 3 phase" thread. It is old and very low tech. So it should be easy to fix. Nothing burned inside. I have already replaced some leaking caps. Only other part likely to fail is a selenium rectifier. That can easily be replaced with modern diodes. Both fuses for the control circuits are still good, so looks like no shorted caps.
I will use this thread as I try to learn TIG welding and see if it still works. I think I have most of this beast figured out. There are a few switches I'm not sure about:
1. Start circuit in/out. The is already a HF start with start/off/continuous positions. I think the start circuit waits for a load then turns on the main contactor.
2. Metallic knife switch. I think this grounds the work side to the case for safety, open position is marked TIG.
3. Start adjustment: May be related to stick welding. I think it sets the initial current.
Came with a MIG wire feeder (feed motor is must weigh 5 pounds), a massive air-cooled stick electrode and a trashed spool gun. No TIG torch, hoses or gas/electrode plate.
I have a Weldcraft WP17 150A air-cooled torch with 25' lead on order. Should be fine for my uses, I did not want to mess with the water cooler. I need a 25' work lead and ground clamp. With the price of copper these days, it will probably be my biggest expense
I'll post pics as I get going. I think I can handle TIG as I have done some mild gas welding. But I bet I'll be baffled at some point.
This thing scares me. That 460A number on the dial is daunting. Amazingly, it goes down to 5 amps.
