I was just going to mention that.Also as the diameter reduces so does the surface speed, which can effect results
It looks like classic low surface speed issues, which is a major factor in surface finish with carbide inserts.
Inserts primarily aimed for steel, typically have negative rake, and rely on pressure/force to keep them engaged in the material. At low speed it can result in the material tearing rather than cutting, which gives a very rough surface finish. However under optimum cut conditions, can produce a mirror finish.
The three main issues with typical steel inserts, is they need a good depth of cut (DOC), a suitable surface speed, and a suitable feedrate.
On a manual lathe, especially at smaller diameters, getting a good balance between those can be challenging. In order to get a suitable surface speed, you need to run the spindle fast, which then means you need to have a high feedrate.
The last thing you want with carbide, is for it to be rubbing the surface, and not cutting.
However, if you want a good finish, aluminium inserts, which have a nice sharp positive rake, can be used for light cuts on steel.
They won't last as long, and are far more prone to damage, but you can get a brilliant finish where steel inserts don't.
The other option are diamond tipped inserts.
