The Graniad said:Let's think about how electricity gets from the national grid to that wall socket, where you plug in the kettle lead that powers your stereo. It zooms along huge cables between big pylons (at very high voltages, because higher voltages can get down long lines with less waste) and then gets turned into 240v at your local substation. Then it travels a fairly long distance from the substation to your house before it comes through the metering stuff. Then the power has got to go up the stairs, around the walls and under the floor to the socket next to your stereo. All of these voyages are fabulous opportunities for the cable to act as an antenna, and pick up radio frequencies that could present themselves as noise in the final sound coming out of your speakers. The cable might stop the last metre or so from picking up radio noise, but if radio noise really is a problem, it will probably be there already, from the huge length of preceding cables. I can't imagine how this expensive kettle lead is going to filter it out.
guess what though I have wired high end systems up for folk a dedicated hager unswitched socket wired separately in 6.omm cable back to a hager db wired tt and a separate earth rod . I said to the guy pity your on the end of a line of houses out in sticks with a crap supplySeems a bit of a shame to plug it into a plastic socket with some years old brass pins connected to a ring main full of noisy open copper, really....
Does it say anywhere that it was made by virgin mermaids ?
All about improving those 1's and 0'sApparently the HDMI cable my mate gave me is a high tech gold plated bit of kit that cost him a lot of money 5 years ago and would make everything look much better.
I tested it against the £1 shop cable I bought...no difference at all, Kim Jong Un was still a little fat fella with a daft haircut no matter which cable I use.
Most of these audiophiles are most probably over middle age. It’s a medical fact that human hearing deteriorated with age, it’s called presbycusis, one third of us will experience this after a certain age. It typically affects our ability to hear mid and high range frequencies most common in the spoken voice range around 4K Hz.
No amount of spending on snake oil products is going to help overcome this
There are some advantages and benefits in having nice kit but there really has to be a limit
I'll stick with my 1210's, my old made-in-melksham Citronic mixer and a pair of old celestions....
In a way this is the crux of it.
A lot of audiophiles are chasing a sound they remember and their hearing is starting to let them down, so they keep tweaking and swapping stuff to get the "perfect" sound.
A lot of the snake oil kit and cables don't have a flat frequency response and mixing and matching can get you where you want.
it certainly wont have a flat response but if your hearing isn't perfect and you like it so who cares?
If you have a high resolution system and you change something you can hear differences. I won't say it right or wrong but you can hear differences.
Listen to an mp3 file on a tinny phone speaker and nothing is going to help.
The whole thing seems pretty harmless to me and no worse than spending the same, or way more on a battery watch (or just a battery!)
its easy to make fun of other hobbies, just think what most audiophiles would say about what we get up to?
