Pollys13
- Wiltshire UK
This is the sandblaster I have see attached screenshot G Ebay item number 281390961318.
The connector on the sandblaster is in screenshot H. I have a 5M Draper air line to connect from the sandblaster to the compressor. The air line has ID 13mm OD 21mm it comes with 1/2" male BSP fittings. The compressor has a spring quick connect coupler.
In my other post I mention reading that the air line length from compressor to pot should be as short as possible? If this is the case and I cut it, what type of connector do I need to fit on the severed end, how do I fit this on the air line? What type of connector do I need on the air line to fit into the coupling on the sandblaster?Or if I don't need to cut it what adaptor/connector do I need for the compressor and pot?
The cabinet inlet connector see screenshot B I've been told this is a,
" The fitting is a 1/4" NPT (National Pipe Thread) coupler. So, it accepts the 1/4" hose fitting on the air hose on the inside of the cabinet, and it allows you to attach a 1/4" NPT fitting from your hose from the sandblaster.
The sandblaster hose see photo I this has a nominal bore of 13mm, nominal as my calipers have a flat batt
What connector do I need to connect the pot hose to the cabinet inlet?
Cheers.
Cheers.
