Hi,
As you may know from my previous posts, I'm learning to arc weld, before I move on to MIG - think it will be a good skill to master.
So you may have seen my welds on 6mm or 7mm flat, they were ok. But when ever I tried to progress onto corners etc, it all went wrong, especially on the 3mm angle I was using, I would blow holes through it as my amp control and arc length were obviously out.
Anyhow, I've been toying with the idea of making a small welding table, just out of an old metal bed frame. I was sure though, that with this angle with holes in stuff it was made from being 1mm, maybe 1.5mm thick I wouldn't stand a chance.
So I read lots and lots of threads about arc length and watching the weld pool. I knew I'd have to drop the amps right down on my clark 160 easi-arc, so then I practised stricking the arc with low amps.
I finally built up the courage today to have a pop at a 45 degree corner out of the dreaded thin stuff! I cut the angle on my chop saw - v badly I have to say! leaving a 0.5mm root gap...just what I didn't need!!!!!
I have to say though I'm very VERY pleased with the result. No holes, decent penetration and a tidy looking weld to boot!
I would welcome any comments on the attached pic.
I know the weld isn't full length, but I was using a set of mole grips to hold the peice together (buying proper magnetic and normal clamps this weekend).
