Screwdriver
If you want a massive bench i.e. very heavy then at the sort of thickness/volume you are talking about, concrete won't add that much mass.
If I was going to make a massive bench, I'd use a thick top, form say a 4-6 inch deep box and fill it with all the junk/offcuts of steel I would otherwise have to dispose of. Weld each piece in place as you go, then if you insist, fill it with concrete. Potting compound,epoxy or even bitumen might be better for filling the voids but could be expensive depending on volume.
A quick calculation suggests a 25kg bag of cement would weigh about 275kg if it was made of steel. You wouldn't want to pick up a bag like that, let alone drop it on your foot.
