Then why not a recip" or a strimmer with a blade on, that will clear most of it, then a pick to dig out the roots.Yeah the brambles are massive, 30mm diameter and over 20 foot tall. There's a couple of Alders (I think) that need sorting out but I'm worried the chemicals will harm the Acer tree nearby.
Are eco plugs what they also use to kill off trees not jus5 stumps of felled trees? I know they use copper nails but I can't see that working quickly to be honest.If you are only dealing with the stumps drill them and push in a couple of ecoplugs.
Bob
Never seen them as big as that and our hedge is an old field one from 1800 and frozen to death I've chased roots with a spade down nearly 3 ft and they still come back.This is what I've got.
View attachment 454619View attachment 454620
They definitely had blackberries on them last autumn.
Brambles in the rh picture to the right of the cut stumpsThis is what I've got.
The thing in my hand was cut from the stump in the right hand photo!Brambles in the rh picture to the right of the cut stumps
The LH picture indicate rose briar which can still be power washed loose and dragged out .
Unfortunately it's leaning over a fair bit although the bottom two courses look solid...Wall not a great problem the posts look solid. A bit of pointing thats all..
@DAPPH I like the trifor idea, I've always wanted one![]()
That'll be the ivy. Killer of trees and destroyer of walls. gets its tendrils into the mortar courses, and forces them apart. Even more so on an old wall with lime mortar.Turns out the soddin weeds are the last of my worries!
Now the ivy and other carp is out of the way I lent on the wall for a well earned break and nearly pushed it over
Or it could be like my old garden wall which was built with a damp courseThat'll be the ivy. Killer of trees and destroyer of walls. gets its tendrils into the mortar courses, and forces them apart. Even more so on an old wall with lime mortar.
