Stud welding / dent pulling with a MIG welder
  1. Mike_H Member
    41
    Northants, UK
    I've got a portamig with a Euro Torch
    Has anyone found a kit to use it as a stud welder for dent pulling. I could buy a cheap stud welder but I don't think it'll last very long, and don't do enough of it (hobby) to buy a new one.
    My current workaround method is to tack weld nails to the dented area, and pull them using a split end on the slide hammer, or clamp with big mole grips and pull the mole grips with a hook.
    It's slow and laborious, but it sort of works. I'd like to find a quicker method.
    I've seen the Eastwood and Sealey parts, but don't think they'll fit a Euro Torch. Does anyone know different?
  2. Ruffian Member
    2,120
    Devon UK
    Speak to your local body work supplier.
    A local one to me does a kit for circa £200 with welder, pins, and slide hammer.
  3. Mike_H Member
    41
    Northants, UK
    Thanks for the quick reply
    I asked my local one but they didn't seem to know what I was on about. Any idea on the brand that your local man stocks? I expect I could find something online.
    Also £200 could pick up a used stud welder and slide hammer, so it's marginal if it's worth it.
  4. stuvy
    stuvy Member
    @Mike_H you must be doing enough of it to need a dedicated machine
    I went to the paint shop earlier and he has a magic dent puller. Basically it spot welds keys then stick a bar through and pull it out for £4500 for the machine
    The old way was a home made slide hammer and drill holes insert a screw and pull it out
    I still see cars like this from time to time
    Shedendman likes this.
  5. Shedendman
    Shedendman Member
    4,063
    east sussex
    Thats how i've done it,tbh though,if poss i just get a replacement panel
    stuvy likes this.
  6. daedalusminos Member
    764
    Norwich
    Check out Trev's blog...
  7. optima21 Forum Supporter
    2,826
    halifax, England
    or tack the edge of washers onto the panel and use a slide hammer through the hole of the washer.
    Shedendman, slim_boy_fat and stuvy like this.
  8. gaz_moose Member
    973
    tamworth staffordshire
    I used to just weld washers on and use the hook attachment on my slide hammer. twist them off when I was done.
    slim_boy_fat likes this.
  9. pedrobedro
    pedrobedro Man at Matalan
    10,257
    CX Derbyshire
    We did this but tacked M6 nuts to the panel and cut the tack off with a grinder.
  10. eddie49 Member
    The Eastwood kit is just a cut-down MIG shroud with a tube to hold the stud/pin whilst you weld it to the panel:
    https://www.frost.co.uk/mig-stud-welding-kit/
    Apparently their tool only fits Tweco torches. It wouldn't be too hard to adapt a spare Eurotorch shroud to hold the pin in the same way.
  11. gaz_moose Member
    973
    what would happen if you put a bolt in the electrode holder of a stick welder and held it against a panel? would it weld it to the panel?
  12. eLuSiVeMiTe
    eLuSiVeMiTe Member
    10,960
    Bedfordshire England
    What about losing the welder and trying cold glue
  13. Mike_H Member
    41
    Northants, UK
    Anything is better than drilling a load of holes in a panel. That’s why I use the washer/nails method now. It’s very slow though.
  14. Mike_H Member
    41
    Northants, UK
    From what I've read, the glue method is good for biggish, shallowish dents, where you have a good surface to attach to. Stud welding (or DIY workaround equivalent) is better where you have an irregular surface or smaller / deeper dents without a flat area to grip on. The second part is based on experience, whereas I haven't used the glue methods personally.
  15. Mike_H Member
    41
    Northants, UK
    If I was to buy a purpose built stud welder puller, any recommendations as to brands? Probably looking for something used and half decent, rather than brand new made from the finest Chinesium.
    I’ve seen Tecna and Rothenberger ones advertised. Rothenberger have a good rep in blowtorches, but no idea on stud welder brands.
  16. Mike_H Member
    41
    Northants, UK
    Update: Found a Rothenberger stud welder / puller for £75 on gumtree, with a load of rivets and a few different collets on it. Tested and working. Bargainous.
  17. slim_boy_fat
    slim_boy_fat Forum Supporter
    Did it come with an operator? :scared: :D
  18. Mike_H Member
    41
    Northants, UK
    Nope, for a quick lesson from the old boy who was selling it (retired from being a body man) and have a scrap door to play with, to get the hang of how long to weld the stud on for, and try the shrinking head.
Advertisements
