I agree, if you look at the diagram the ones in grey are for the balance and the ones in white are for pulse, see below, black line is balance, yellow is pulse.i think that knob also doubles as the pulse duration
Pictures, pictures...I have a similar problem with the saf fro 350A Tig at work.
I mostly use 2.4mm tungsten, but whenever some other touches the welder, parameters goes off.
I usually go for 55 to 60% balance, I don't know if positive or negative.
Anyway sometimes I have to reset parameters but it stays locked on 70% even moving the potentiometer and it doesn't weld anything.
It doesn't melt material.
Now I know it's a machine's fault and I'm not pretending someone to tell me how to fix it because I can't as it's not my job, I'd just like to know what numbers mean to understand it better.
The knob has tungsten diameters as reference and the number increases going up with diameters.
It's not mine , on Monday I'll try to show you somethingPictures, pictures...
