Whereabouts are you? I build stoves, so I use a fair amount. I've found the best way is to ring around your local glass companies. One of them will stock it, commonly also called contratherm, ceramic glass or boron glass too. It should be half the price of stove shops selling pieces for specific stoves. Rope is available on ebay as already stated, just check your size. I only keep 8mm, which I buy in 25m rolls, along with paint, direct from the manufacturer.
to give you a hint look deeper on ebay
Calfire Replacement Stove Glass Aarrow APEX (260 x 220) - FREE Thermal Tape | eBay
AARROW APEX. Size : 260 x 220 x 4mm. Gently finger tighten the screws and washers to hold glass in place. Suitable for replacing glass in Over tightening may crack the glass. High temperature heat resistant ceramic glass specifically manufactured to cope with temperatures in excess of 760°C.www.ebay.co.uk
Again cheers for those. I had found them already.Aga Little Wenlock Classic Stove Glass (230x210 - Plain)
AGA Replacement Stove Glass Heat Resistant For AGA Stoves | eBay
Find many great new & used options and get the best deals for AGA Replacement Stove Glass Heat Resistant For AGA Stoves at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
check it will fit its smaller just
Calfire Replacement Stove Glass Stovax Blenheim (230 x 207) FREE SEAL/TAPE | eBay
Stovax Blenheim. Size : 230 x 207 x 4 mm. Gently finger tighten the screws and washers to hold glass in place. Suitable for replacing glass in Overtightening may crack the glass. High temperature heat resistant ceramic glass specifically manufactured to cope with temperatures in excess of 760°C.www.ebay.co.uk
