carl0s
- Kelsall
I am still confused on this single-phase vs 3-phase motor rating stuff.
Since buying a '3hp' compressor (SIP) that runs off a 13a outlet quite a few years ago, I've always assumed '3hp' to be somewhere within the realms of a 13a mains outlet. In fact, 3hp single-phase motors are rated at 2,200w - a little less than an electric kettle, and if it wasn't for start-up surges, inrush currents, whatever, then 10a is basically what they draw. but usually a 16a slow MCB is needed, however that's another thing.
When I started measuring up for my new KRV2000 mill, I was sort of surprised to discover that a 2.2kw 3-phase motor doesn't just need the same 2,220 watts from the wall (to the VFD) as a single-phase motor. Apparently the watts are 'per phase' (that information wasn't exactly forthcoming..), but then because not all 3 phases are pushing at same time, so to speak, it's 1.732 (square-root-of-3) times 2,200w, which means the motor needs 3,810 watts, plus whatever overheads the single-to-3-phase converter has. The VFDs say they need 20 - 24 amps which I just found really surprising. However I have accepted that and it's not a problem, I will size T&E accordingly!
What I still can't get my head around though, is how the horsepower ratings can be the same between a 1ph-3hp-2200kw (10A from the wall on 220v) motor and a 3ph-3hp-2200kw (17.32A from the wall plus VFD overheads).
I do now understand that 'watts are not watts, when you're comparing single-phase to 3-phase', but how can a machine mart 3hp compressor run off 10A while my 3hp mill motor plus this VFD (https://inverterdrive.com/group/AC-Inverter-Drives-230V/Delta-VFD022EL21A/ ) requires ~20 amps.
Are the HP ratings not mechanical shaft horsepower ? Are they simply stating the per-phase-electric ratings in horsepower instead of watts?
yeah, still a bit confused..
