Norsk
- Norway
Cut the front of the muffler in a square "U" shape. Cut the baffle out,you likely have a spark arrester but maybe not,they are a type of heavy gauze.Apparently they are not they look fine to me
I'm tempted but it's kinda hard to do that...
There's no spark arrestor for sure on mine, but the internal baffle is pretty complex to remove cause the muffler is not welded but the sheet metal is bent around one each other of the two halves of muffler.
So it's going to be a PITA to remove it .
Although it would be great for the ignition module as it seems that if you don't let the saw idling for at least 30 second before to shoot it off, it will fail.
At least that's what I've read here and there on the net.
I've already ported my little Jonsered and she was a little beast for having 40cc only (it was born as 36cc but I've put an husky 140 cylinder in it)
Yes I think they are two actually, one on each side of the heat shield
Bend the flap back so it forms a type of chute,use the baffle as material to cover each side of the chute as you weld it in. Blank off the original exhaust hole.
There always seem to be a few types of muffler for each saw,its been yonks since I used a 361 but that's how we used to do 361,044,046 back in the day.
Sounds peculiar re your ignition module,I have honestly never heard of that but your saw is getting on a bit
