pidgeon chit welder
sticking metal since 1962
Testing that chain saw.
Get hold of a flexi tube connecting pressure gauge and whip out the spark plug, look for 18 to 24 PSI dry test .. add a teaspoon of light oil to the cylinder and pull it over , if it increases by a large amount walk away the barrel & piston is shot and it's a fair bet that the crankcase seals will also be Koofed.
On the bar look for flats worn where the chain runs in the bar groove if you see these and there is any evidence of the bar being scalloped out or burrs on the edges of the bar .. its a new one of each.
slip the side cover off and look at the drive teeth any deep gouging will usually see you needing a new one .
Check the brake stop by revving it up holding the rpm and knock the brake on it should stop the chain running but not quite stall the machine but it should make it stutter some what.
I have repaired hundreds and hundreds of chainsaws and firmly believe that like women .. you don't buy a second hand one unless you give it a good going over first.
For amateurs just don't go for the second hand version of either unless you have experience.
