BrokenBiker
- Newport, South Wales
is an exhaust system too thing for stick welding with 2.0mm rods?
the exhaust on my megane isn't original, instead of having the original one piece stainless system, it has now got front, centre and rear sections made from galv steel and cheap looking centre and back boxes.
the joint from centre to rear section is blowing, and I have tried every clamp possible to try and tighten it down to no avail. have used all things like gungum paste, the kits for wrapping the exhaust, using grease as a form of sealant but it all fails. once again the exhaust is blowing from the same spot...
anyway, I can get the exhaust off, and put it back on with the centre and rear sections joined, so I want to weld it and stop it blowing once and for all, but my mig is in bits and I only have an ac bizz box available and some 2mm or 2.5mm e6013 rods.
will I get away with welding it or will it just blow through?
just touch it and it will be through
