The next weld is gonna be hard work with a miss shaped unstable arc.
You'll only improve things for yourself further if you keep your tungsten clean. If I was to contaminate my tungsten through dipping or rod contact I'd immediately re prep it. Even if it's not critical work because of what it does to the arc. The next weld is gonna be hard work with a miss shaped unstable arc. Don't cut little corners on your welding prep because it's for DIY purpose. This is the best type of work to perfect everything because you have the time on your hands. And you'll be a better welder for doing so. I'm meticulous about every bit of it and I do get some lovely results because of it.
I thought they just cost more and didn't last as long. I'd rather have a rigid head or save up for a flex loc.Flex head torches are a must!!
Says the man who still hasn't bought one yet! Ha.
I've only ever changed one flexy head in 10 years, buy decent to start with and they will last
If they don't break under the use they get from you, then mine will see me out![]()
I don't bend them to stupid angles as its obvious they won't last.
