Since I have this project coming up soon, I might as well ask...
I have a circular saw to cut steel bars on a home made stand (don't know if there's a specific name for it) - you know the one which has low revs and sucks up oil with water to squirt it on the blade while cutting, anyway, I need to make two roller stands on either side of it. The left side to rest the length of the steel bar while it is clamped and the right side to rest the cut piece.
I was thinking of constructing these myself since the ones I found on sale were too expensive and also too short. The simplest method would be an angle iron or hollow section frame about one foot wide and as long as....uhm the available space in the garage with rollers at, say, every 2 to 3 feet apart.
The frame isn't a problem. The rollers are though! How do I go about constructing them? Preferably a length of steel tube with bearings at each end...but I don't have a lathe to turn the internal diameter of the pipe. Maybe I could find bearings which already fit snugly but I have to be more than lucky!!
Any great ideas?
Any great ideas?
