I'm a decent welder, and I'd be able to manage at home just fine for 90% of what I'd use a TIG for.
I think a lot of what you get from a TIG comes from the operator, ok there's times I'd like a better duty cycle or a bit smoother AC output, but I'd easily work around it.
For the home user or the shop where AC isn't in use day in day out I can see it doing a great job for the kind of dough people are prepared to spend on a tool that effectively is a luxury item as it earns them no money.
What you've never welded ali?I got an AC/DC TIG set - I could live without the AC function.
To be honest I got two TIG sets one DC and the above mentioned. I really talked myself into a AC/DC set and like lots of people I have never used the extra function. Mine is getting abit long in the tooth now = Lincoln V205T
Cheers qwakerswel at first glance you are in ac sine wave (bottom left) you want dc for steel (far bottom option)
that disables all the ac controls so should work fine. assuming you have the torch and earth in the right ports (not reversed) it should be good to go. do check you have proper gas flow though, i had this issue when i thought i had good flow but i didnt.
Hurrah thought I was alone- I often get alloy wheels offered to me - bodge up cracks - but I won't do them (as I don't think it is safe).
Not a lot. Most of the stuff I TIG is either steel or DC TIG brazing.
I am a motor mechanic - I often get alloy wheels offered to me - bodge up cracks - but I won't do them (as I don't think it is safe).
I never really make/fabricate new stuff - mine is all repair welding - bodging and bolt extraction.
