I might be able to blag the odd replaced Lorry Brake Drum from work. I'd thought of using one before, but wasn't sure if the footprint was big enough for stability (if freestanding & not bolted to the floor).
I wondered about doing all the metalwork then filling the drum with concrete? For a vice stand.I might be able to blag the odd replaced Lorry Brake Drum from work. I'd thought of using one before, but wasn't sure if the footprint was big enough for stability (if freestanding & not bolted to the floor).
Once you've mounted the drill press, I'd be interested to get your thoughts.
(I needed mine to be movable, so it's on a wide base and castors - & my Clarke drill is very top heavy & I had visions of it going over like a felled tree)
I had the concerns (for a vice stand) being greater about tip-over than for a drill press when in use - because you might have a long hefty "something" in the vice, and applying quire a bit of force to it of your own - so went for a tripod design vice stand (it can be broken down if needed, but for general moving about I added two fixed small castors to the front legs, so I could tip the stand towards me to easily move it about.I wondered about doing all the metalwork then filling the drum with concrete? For a vice stand.
It would be more than heavy enough but you could tip and roll it on edge if you needed to Move it ever
You could go and play Twister... or Risk.Can I sit down now? I've been standing since I read the post title & my legs are tired!![]()
2 different songs!You could go and play Twister... or Risk.
Let's see how many get that one![]()
REM - Man on the moon. Both games mentioned in the first verse...just saying.2 different songs!
I think he meant that Stand and Man on the moon were two different songs.REM - Man on the moon. Both games mentioned in the first verse...just saying.![]()
Oops! My mistake!I think he meant that Stand and Man on the moon were two different songs.
that would be a fabulous sundial stand for the garden !That's very nice of you to say
Thankyou.
Grinder one
