Stainless grade question
  1. Mike B Member
    160
    North Wales
    Hi everyone,
    Can one of the more experienced metal gurus recommend a few types of stainless for a project?
    I need something in stainless which is highly corrosion resistant and easy to turn, weldability is desired but not essential.
    Seen a few offcuts of 431 on ebay but turns out it's difficult to machine and needs to be pre-heated to weld.
    Any suggestions, or anyone got something suitable lying around?
    Needs to be approx 2.75-3.25" dia round bar, and I need two pieces approx 80mm long
    Thanks for help
  2. Munkul
    Munkul Jack of some trades, Master of none
    3,144
    Cumbria
    How highly corrosion resistant?
    We tend to use 316L for most things, and started using super duplex 2509 for tanks/pipework subject to low level chloride or sulphide corrosion.
    316L machines pretty well and welds very well. Duplex is quite a bit tougher to machine.
    Then we jump up a huge notch to nickel alloys for anything worse.
    316L is pretty good is passivated properly.
    Gwil likes this.
  3. TechnicAl
    TechnicAl Member
    8,240
    Rotherham
    What is the application?
  4. Mike B Member
    160
    North Wales
    I think 316 will fit the bill. It's for a small hydraulic fluid cylinder to be fitted to a trailer.
    Anything with similar properties to 316 that I could also search for? The idea being the more grades I can search for, the more likely to find a cheap(er) offcut from someone.
  5. TechnicAl
    TechnicAl Member
    8,240
    Rotherham
    316L will be the cheapest.....other grades are rarer
    Mike B likes this.
  6. TechnicAl
    TechnicAl Member
    8,240
    Rotherham
    Just a thought......you might also look for A4 stainless, which is 316L used in nuts and bolts
    Mike B likes this.
  7. Mike B Member
    160
    North Wales
    Thanks gents
  8. Kram
    Kram Member
    1,781
    Sussex
  9. TechnicAl
    TechnicAl Member
    8,240
    Rotherham
    The F51 is Duplex.....really should be welded with a specific consumable
  10. mike os
    mike os just a little insane.....
    6,971
    North Wales
    shouldn't need to be "better" than 316 unless its a really nasty environment
  11. Mike B Member
    160
    North Wales
    thanks for that link. Tried him but the F51 is apparently difficult to weld unless pre-heated. I found some 316 eventually
Advertisements
