Seadog
Save the planet. It's the only one with rum!
- NE London - UK
It's a vacuum furnace - $100,000I just skimmed the pdf, does the furnace need an inert gas ?
There is a bunch of powdered metals plants nearby in St. Mary's Pa.I think the high end ones use a vacuum furnace.
I don't see why you couldn't use the same methods as heat treating high tolerance parts, ie, inert gas purge or encasement methods?
Were these arts & crafts items ?I’ve got a few items, made in silver and sintered, that my wife made. Used silver clay ‘putty’ - dried and then popped in the kiln at a suitable temperature. I suppose 3D printing is just an extension, to the art, with at least reproducible results.
They all have large tanks of Liquid Hydrogen & Nitrogen for the sintering furnaces.
Some have added the metal injection molding process to their capabilities.
I would suggest that heat treating and sintering, while both thermal process's,
are not interchangeable.
I'm thinking that it will all fall down into a pile of melted mush if the $100k furnace isn't used.I didn't mean that you could use the same process, just that (at a hobby level at least) you could use the same equipment.
It must be possible to print this stuff in your shed otherwise what's the point of it?
No use me paying £200 for a roll of filament because I can print it in a £300 printer if I then need to spend £50,000 on a furnace to finish the part.
The 3D metal printing has been about for quite a few years, there was a Siemens network of companies that would do the Green sintering for you, its not cheap, but its just a follow on from the older MIM techI didn't mean that you could use the same process, just that (at a hobby level at least) you could use the same equipment.
I think the process controls are pretty stringent to get the binder out, the particles
of SS knitted properly, and at the right times.
I know what I don't know.I can't see how an expensive furnace can stop it falling down any better than a cheap one?
A vacuum furnace will remove any out-gassing and possibly any traces of the binding agent.
But an inert purge should also flush out gasses and I'd guess the filament is designed not to produce any negative gasses anyway?
Lost casting filament is already available that leaves virtually no ash and the 99% pure metal I've seen mentioned seems believable enough.
Process control instructions are pretty strict, you would at least want a kiln with a programmable controller and have your temperature control fairly well sorted for accuracy.
I'm not sure how important it would be to have perfectly even heating and even temp rise and so on?
It would make sense that everything would need to be 100% perfect yet, on the other hand, you can print odd shape parts. So if you have a part with a 50mm thick lump and a 1mm feature that won't heat up evenly in a 100k furnace so what shouldn't matter if a budget furnace has a bit of wobble during the ramp phase?
When you design your parts, just like you would for normal plastic 3D printing, you design in supports, but mainly you try and make them easy to mill/saw/file off.I can't see how an expensive furnace can stop it falling down any better than a cheap one?
A lot of the Cylinder deactivation valve train components are MIM and its an almost identical process of debinding and then sintering and lets you design/create complex components that would be to small/complicated to be machined even on a bar fed CNC
Watch the video. All is explained.
If i remember correctly from my visit with to the factory (its been 20+ years since i dealt with it, so im a bit rusty.) , the filament/moulding putty has different binders/fluxes that bond at different temps. when the part has been debinded from its green stage, its called a brown part, and that is the most fragile stage, (yes they lose a few) but there are low temp solders holding it together,That makes sense.
I guess you would have to put in supports to print it anyway so you just print on a raft, take it off the printer complete with the supports and pop it into the kiln?
Then trim and finish like a cast part?
So what stops everything (including the supports) falling apart once the temperature is high enough to burn off the binder but not yet high enough to fuse the metal powder?
Or does the binder actually turn into something else rather than just burn away?
Correct.Just had a quick look at the video but that looks more like he's using the powder and casting like I mentioned earlier rather than printing directly with stainless filament as mentioned in the first post of this thread?
@hotponyshoes this is a company we used to work with about 20 years ago on fiber optic terminations, we could get better than 0.05mm accuracy on some parts
its MIM but most of the principals are the same.
You can get other metals other than just stainless.
